JDout
#1 Posted : Thursday, May 21, 2015 4:55:37 PM(UTC)
JDout
Hello all,
I have a Maytag washer MHWE201YW00 that went out shortly after our house was hit by lightning. I was getting an error F6 E1 code (error in connection between motor control unit and control board).
I have replaced the control board on the side (part # AP5618612) and am still having the same problem.
When the start button is pressed the door locks and there is a short buzz and then nothing. No water or other noises. I have to unplug the unit to try it again.
Has anyone had this problem or know how can I check voltage to find out where my problem is? Should I try the front control board and motor to fix this?
Thanks in Advance
Josh
JDout
#2 Posted : Saturday, June 6, 2015 1:58:23 PM(UTC)
JDout
bump
(10 char)
EPEaston1
#3 Posted : Friday, April 15, 2016 10:37:33 AM(UTC)
EPEaston1
Hi. Did you ever get an answer to this question? I have the same model and same issue. Thanks.
JDout
#4 Posted : Friday, April 15, 2016 10:42:29 AM(UTC)
JDout
Checked electrical with a meter and never could find anything wrong. I just bought a new one (LG this time) the next time Lowe's had washers on sale. I probably spent more money buying parts and wasting time trying to figure out what was wrong then I did on the new one.
