I have a couple of questions......I am trying to find a manual for this freezer. I know it is at least 35 years old. I found a parts diagram but that is it. Sears says it is manufactured by Whirlpool so I called them with no luck. I am also trying to figure out what the orange light on the outside of the door is for. I assume a power light? I thought it worked before we bought it but not 100% sure. Any ideas would be appreciated.
Joined: 2/29/2008(UTC) Views messages in topic : 19,638
I also cannot find a manual.
What is wrong with it.
If it will not start up have you left it plugged in for at least half an hour? Just to be sure that you are not in a defrost cycle. |
THIS FORUM IS DEAD!!!!!!! |
I believe it appears to be working fine now but the light still doesn't come on. . I have it on setting 4 out of 7 and it is 10 degrees inside. I was hoping someone knew about the light. Maybe I'll try some local shops?
