Dryer works intermittently and just once in a while. I have replaced the 1. Thermistor (3976615) 2. Heater Element (33877470 3. Thermal Cut-off (3977394) 4. Thermostat 250 F (3390291) 5. Thermal Fuse (3392519) and it still just works intermittently. I don't know if there is anything else to replace to make it heat consistently? Anyone out there have any help for me? I probably should have just bought a new one before spending so much on parts, but I thought sooner or later I would fix it. Stephen
Groups: Expert
What do you mean by "works intermittently"? Won't start? Won't tumble? or runs ok but won't heat? This is an evenheat model and probably has a faulty control board as this is a very common failure item, but it could be the heat relay is failing. You could swap the two relays in the control panel. One is for the motor and the other is for the heat element but the relays are identical. If that does not seem to be the problem, then replace the board. Examine it for burned components. http://www.appliancepartspros.c...w10116565-ap4319168.htmlEric
