jasperjasper
#1 Posted : Friday, May 15, 2015 4:59:12 PM(UTC)
jasperjasper
I need to get the spray arm off to inspect & clean underneath it.
I got this plastic piece to turn a bit, and it's partially out, so the threads are a little exposed, and the spray arm is wobblier. I can turn the piece by hand. But the piece won't come out, and the arm won't come off. I can't get it to screw back in again, either - it just spins.
How badly have I messed it up?
Is there a way to get it off?
I'd be fine with destroying the piece, if I knew I could replace it and if I wouldn't damage anything else.
jasperjasper
#2 Posted : Saturday, May 16, 2015 4:55:41 AM(UTC)
jasperjasper
[IMG]https://plus.google.com/107156766161378644824/posts/Bm7MYyhPFVG[/IMG]What I called "sprayarm" is actually the "Wash Arm Assembly" 8268332.
What I called "plastic screwpiece" is actually the "Lower Spray Arm Hub" 8268342.[IMG]https://plus.google.com/u/0/photos/107156766161378644824/albums/6149451158233409441/6149451159789096658[/IMG]
The photo shows how far I got.
What's next?
jasperjasper attached the following image(s):
