egizzi
#1 Posted : Friday, May 15, 2015 6:06:30 AM(UTC)
egizzi
This is one of the older model dual fuel ranges with a downdraft system. In the process of forcing a venturi bolt out, I cracked the jet bracket and twisted the gas line going from the valve (at the knob) to the jet bracket.
There is no replacement aluminum gas line part for this.
There is a newer design gas valve that also looks like it is not available.
Questions:
1) Might it be possible to get aluminum gas line repaired or fabricated?
2) Could there be other valves (at the knob) that could be used as a substitute? And then I could use one of the newer model gas lines?
I sure would like 4 burners instead of 3.
