My old touch display was difficult to read but worked. Ordered a replacement. Carefully fitted it. When powered up new display works, can set clock etc BUT keeps repeating error message. Rechecked fitting. Same result. Refitted old display. Works perfectly - but still faded and difficult to read.
Is new display faulty or wrong unit? Any clues?
Hello Dave305. We need to know what error code you are getting. If it is for the key panel, then you need to check the ribbon cable connection and make sure your seating it good in the connector. If it is not seated good, you will get and error code for it.
