Refrigerator light comes on sometimes and then will go out. You may open the door and the light will work normal. It may stay on the time you have door open or it may go off. You can close and then reopen and it may be on or may not come on. Have tightened bulbs but this does not help. The freezer light is working fine. I see the freezer door switch, but do not see a refrigerator switch. Any ideas to try. Thanks
Hello Wadams. You will need to check the main board on the unit and all wiring connections on the unit. Part number: AP3683024
