The oven starts but it can not heat enough to cook The temperature control confirms temperature, it advices that the oven is ready but it does not cook as usually
I cannot find any info on the given model number, please check it.
Could be a couple things.
1. One of the elements is not turning on. During preheat and bake most units switch back and forthe between the bake and the broil elements. This gives a more even temperature profile in the oven for better baking results. Some oven will come ready but usually it takes longer than when both elements are OK.
2. The oven sensor may be bad. Check the oven temperature with a thermometer. |
THIS FORUM IS DEAD!!!!!!! |
