SnowFrost
#1 Posted : Friday, May 1, 2015 12:48:09 AM(UTC)
SnowFrost
I got a freezer defrost timer that is see through on one side. It looks like the resistor inside the timer is dangling and no longer connected. But the fridge/freezer is still going.
Can this cause a risk or is there a main fuse in a fridge to prevent electrocution?
#2 Posted : Saturday, May 2, 2015 2:25:32 AM(UTC)
[COLOR="Blue"]Can this cause a risk[/COLOR]
I cannot say without being there.
[COLOR="Blue"] or is there a main fuse in a fridge to prevent electrocution?[/COLOR]
There is not a fuse in the fridge.
The circuit should be protected by your electrical panel.
Also the unit should be connected to a properly grounded receptacle (3 prong).
Then if the live side of the line shorts to the frame, the current flows through to ground and also blows the breaker.
SnowFrost
#3 Posted : Saturday, May 2, 2015 4:45:42 PM(UTC)
SnowFrost
I would have thought the timer resistor is in relay to earth to get a circuit. So maybe it is still touching. Whatever is happening it is running.
My biggest concern was the lack of circuit in a defrost timer causing a fire.
I just want to feel a bit confident.
I tested the thermostat first and got 0 omhs even though it does look like the top is lifting.
So I thought it might be the defrost timer. When I looked at that I could see the resistor looking like its not in relay. Being very non educated in electrics I just freaked out a bit with worry about safety.
#4 Posted : Sunday, May 3, 2015 12:22:26 AM(UTC)
Sorry but I cannot find any info on this unit.
I can tell you that if the defrost thermostat is deformed/bulged it should be replaced even if it checks out OK with a meter.
