I bought a craigslist, converted to propane, stove. After hooking the thing up and confirming gas is making it to the back of said stove, I cant get any gas to the burners.... Now, this is what I may have done wrong.....I hooked the propane tank up first without a regulator. (I thought the one on the stove was enough). When I turned it on MUCH gas came out of the burners. I did this once and then realized what was wrong. Now, no gas comes out?
Would anything "break" by having that amount of pressure for a short burst? My propane tank and regulator that is feeding my stove also feeds and still works on my on-demand H20 heater. I have confirmed gas coming to the point of inlet to the stove regulator.
