Was successful in get the old auger out, not sure how to remove the blades to install on the new auger I just ordered.
First you have to (if you haven’t done so) remove the clear plastic crusher cover. Then remove the E-clip off the front of the housing. Once done there is a white nut on the end of the auger at holds the blades on. Note you must have some way to know what order the blades and spacers go back so draw a picture or lay them out in the order they come off. This page will help Ice Dispenser Repair For GE Refrigerators
