buck hunter67
#1 Posted : Friday, April 24, 2015 5:22:19 PM(UTC)
buck hunter67
hello i have amana side by side evaporator frosted up fan checks out ok have voltage on wires and compressor comes on when turned on but evaporator fan will not come on any ideas
#2 Posted : Saturday, April 25, 2015 3:16:19 AM(UTC)
Here are your parts.
Parts for SXD25QA3W - AppliancePartsPros.com
You will have to choose the correct unit from the Matching Model Numbers section.
Check across the fan for 120 volts AC.
If you have it and the fan is not turning, replace the fan.
I cannot find a wiring diagram for this unit so do not know if you will have to hold the freezer door switch closed to get the fan to run.
Freezer working fine refrig not cold enough (Refrigerator & Freezer Repair)
by Tucson_Mike 8/8/2015 7:01:52 PM(UTC)
Freezer and frig not cold enough (Refrigerator & Freezer Repair)
by Chargersrlh 4/9/2013 2:31:26 PM(UTC)
GE refrig not cold enough (Refrigerator & Freezer Repair)
by GaryVA 11/18/2012 11:56:13 AM(UTC)
refrig not cold & water in it (Refrigerator & Freezer Repair)
by kjbh1960 6/11/2012 6:17:44 AM(UTC)
Freezer not Freezing and Frig not cold enough (Refrigerator & Freezer Repair)
by FrancyJ 4/2/2012 3:37:52 PM(UTC)
Another Freezer/Frig not cold enuf..but unique !! (Refrigerator & Freezer Repair)
by Barry2 9/29/2011 4:07:51 PM(UTC)
Freezer fine, refrig not cold enough (Refrigerator & Freezer Repair)
by boolabonga 9/2/2011 4:27:19 AM(UTC)
Both freezer and refrig not cold (Refrigerator & Freezer Repair)
by JTIngram 8/24/2011 7:32:29 PM(UTC)
freezer working good frig not cold no frost on freezer coils (Refrigerator & Freezer Repair)
by ch123 6/12/2011 11:05:01 PM(UTC)
Whirlpool Roper: freezer/refrig not cold enough (Refrigerator & Freezer Repair)
by Jzerb 6/12/2011 8:12:36 AM(UTC)
by CandyL 4/17/2009 3:15:52 PM(UTC)
Top of Freezer and top of Frig not cold enough on side by side (Refrigerator & Freezer Repair)
by PleaseHelp 11/13/2008 8:07:43 AM(UTC)
sub zero 532 - compresser will not stay on, refrig not cold (Refrigerator & Freezer Repair)
by malisdad 9/15/2008 11:54:35 AM(UTC)
Freezer and Frig Not Cold (Refrigerator & Freezer Repair)
by rogo56 3/25/2008 11:42:27 AM(UTC)
Refrig not cold (Refrigerator & Freezer Repair)
by bwall117 12/12/2007 2:14:42 PM(UTC)
