Have a GE Monogram side by side refrigerator and the LED lights in the produce drawer and above the top shelf quit working. Read some of the posts on this site and tried turning the master switches on and off, but it did not work. Also removed bottom plate and checked fuse for continuity and it was ok. I do not know how to check or reset the two circuit breakers down below. Do you remove them? Is there any where else to check before removing LED lights and checking them? I do not think it is the lights because they both went out at the same time.
What an answer for a place that is a repair forum. Makes me wonder why suebik is part of the forum, since you don't need parts or help. Just call the repair person.
