paulmy
#1 Posted : Wednesday, April 22, 2015 6:47:41 AM(UTC)
paulmy
My Front load washer stops filling after a couple seconds. I tried to run it in all cycles. Even the drain/spin cycle stops after a few seconds of draining. I can cancel the cycle and restart. Same thing happens, unit runs for a few seconds and stops. Any help would be greatly appreciated. After doing some more research I was able to make out the model # as FTFB4000GSO in think.
sidfink43
#2 Posted : Thursday, April 23, 2015 5:00:31 PM(UTC)
sidfink43
Look inside the lower service panel for tech notes and see if you can do some testing. Concentrate on the door lock assembly which if defective can cause your problems. Also check the two boards.
