samknopf
#1 Posted : Monday, April 20, 2015 6:33:10 PM(UTC)
samknopf
So my model is WRB329DMBM. I've pulled the rear cover off and confirmed my motor and door are functioning properly to allow cold air in from the freezer. However it will not close on its own, therefore inhibiting the freezer from freezing. I believe I've narrowed it down to either A the harness aka the temp sensor isn't functioning properly and is keeping the door open or B the board is causing the failure of communication. I inspected the board for any visual problems but found nothing
samknopf
#2 Posted : Monday, April 20, 2015 6:36:38 PM(UTC)
samknopf
I'm just hoping someone knows a bit more and can point me in the correct direction. I unplugged the harness to the door and motor and am going to let it sit for a bit and see if it freezes the waters in it, so i'll know the condenser and everything are working properly as well.
