My oven & broiler wont ignite, sometimes I can get it started for a second then it fizzles out. Ignitors glow red so I assumed bad gas valve. Replaced valve and still no combustion. Did research and found that ignitors have to supply 3v to gas valve. Broiler ignitor supplies 3.1 and oven 2.8 while glowing. There are no obvious shorts on the control board. Range works fine. Before I buy another part (2 ignitors) was hoping someone could shed some light on my problem. Thanks :confused:
