Herennow
#1 Posted : Tuesday, April 14, 2015 3:36:40 PM(UTC)
Herennow
whirlpool duet sport dryer F29 reappears.
F-29 is for the Moisture Sensor Shorted.
I replaced the two bars and it still does not heat up.
F-29 code is still showing? Any ideas why after replacing the
Moisture Sensors there would still be a problem.
And the dryer still showing the F-29 error code?
Thanx.
#2 Posted : Friday, April 17, 2015 5:40:37 AM(UTC)
Parts for Whirlpool WED8500SR0 Dryer - AppliancePartsPros.com
I am assuming you have the tech sheet/wiring diagram as you know what the error code means.
Unplug the unit.
Disconnect the moisture sensor at the control board.
Plug the unit in.
If you still get the error the problem is probably on the control board.
