robertmspeakout
#1 Posted : Monday, April 13, 2015 8:23:12 PM(UTC)
robertmspeakout
Came home a couple days ago to a warm fridge and freezer. The unit was beeping twice every few seconds. Since then, i have replaced the control board and the inverter box. When I replaced the inverter box, it worked fine for about 6 hours and then returned to beeping and warming up. The control board swap didn't do anything apparent.
We did have a major storm come through that day - so I don't know if this was a surge issue or not.
NOTE: About a year ago the fan stopped working. I replaced the fan with a new one and that wouldn't work either. After reviewing information online, it was clear this may be a inverter box issue. Instead of bothering with the expense of that, I rigged up a small handheld fan to the same spot the OEM fan goes to and attached it to a timer plugged into a separate outline to run every ten minutes or so. It's worked great for more than a year. No problems at all.
robertmspeakout
#2 Posted : Tuesday, April 14, 2015 7:14:43 AM(UTC)
robertmspeakout
I've just recently been told I need a new compressor. Not sure if that's right or not.
KitchenAid KSCS25INSS00 ice maker not ejecting cubes (Refrigerator & Freezer Repair)
by lunadesign 7/18/2019 7:42:22 AM(UTC)
