You have been a member since:: 4/8/2015(UTC) Posts: 1
Just moved and our GE fridge will no longer get cool. Compressor seems to be working and feels warm to the touch. I can feel the compressor fan blowing as well. We let the fridge sit for 48 hours before plugging it in a the new location and it has been plugged in overnight. Still not cool.
Any advise would be helpful.
Sounds like it is toast.
Confirm that the compressor, the condenser/compressor fan and the evaporator/freezer fan are all on.
If they are all on and you are not getting any cooling then the fridge is toast as it has a sealed system problem. This will be an expensive repair as you need a pro, often it makes more sense to put the dollars towards a new unit. |
THIS FORUM IS DEAD!!!!!!! |
