got new washer pump for model la5500xsn1 put on washer filled with water ran fine got to the point where it is to drane and it locked up and wont drain or agatate or spin dont know what the problem is can anyone help
Groups: Expert
Pull the pump off the motor and see if washer will agitate or spin without the pump. If it does, then something must have gotten into the pump and jammed it or it's a defective pump.
Eric
