Remove the kick plate and try to determine which pump is running.
It sounds to me like the wash pump but without any water is the unit. |
THIS FORUM IS DEAD!!!!!!! |
So, after further investigation, and taking the kick plate off to see which pump it was, I determined it isn't a pump at all. It's the blower motor in the door. Part ordered (assuming that's the only moving part in the door that would make that kind of noise).
