We replaced the control board about a year ago after a thunderstorm knocked out the machine completely.
Of late, we have had an issue where pushing the start button doesn't start the dishwasher. Only when we use the delay function does the dishwasher start - after the time has elapsed on the delay clock. This becomes rather inconvenient if we need to get the machine going and instead, have to wait an hour before it even starts!
What part do we need to fix this issue and is it difficult to do?
Thanks!
Sorry but I cannot find any info on the given model number.
Please check it.
Could be a problem with the start switch not closing. If the unit uses a control panel (keyborad) that is the most likely culprit. |
THIS FORUM IS DEAD!!!!!!! |
