jdphoto@sopris.net
#1 Posted : Tuesday, March 10, 2015 7:27:50 PM(UTC)
jdphoto@sopris.net
GE electric dryer turns but does not heat up
Is it the heating element? Thermostat?
Thanks very much!
#2 Posted : Monday, March 16, 2015 3:44:27 AM(UTC)
Parts for GE WSM2420TAAWW Washer Dryer Combo - AppliancePartsPros.com
I cannot say what part is bad if any.
You will have to check the items with a meter.
Be sure to unplug the unit when doing this.
All thermostats should be 0 ohms (items 294, 274 and 263 in section 07).
The heater should be in the 8 to 12 ohm range (item 269 in section 07).
I would first check the power.
Try flipping the breaker off/on slowly, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
