The lights on my adaptive wash, rinse only, start & cancel buttons are staying on consistently but not as bright as if you were to choose that option to wash. I tried pulling the ribbon and then waiting and putting everything back together. At that point it ran for a few minutes and then drained everything. After that I tried to run it on a normal cycle just to see if it would work, the normal light just started flashing at me and it did not do anything.
Any help would be great. Is there another sequence of things I can try to reset? Do I need a whole new panel?
