3 wire, 208v service. 30 amp breakers. The machine will run briefly, but will ultimately trip the breaker. Unfortunately, I have no witnessed this myself (it is my mother's machine, and it has happened to her on two consecutive occasions). While poking around inside with the ohmmeter, I found a short to ground from a wire that I traced back to the timer motor. The short was only 1.012 megohms, but I thought that might be enough leakage to throw the breaker over time. So I purchased a replacement timer here on APP, but the replacement timer has the exact same 1.012 megohm leak to ground, so I am assuming that this is not a problem, but exactly how it is supposed to be. So, I continued to poke around, and I found a dead short to ground from the black wire on the push-to-start switch. The switch itself is okay, as the short persisted when the conductor was disconnected from the switch. The wire then splits - blue to the door switch and black down to the drive motor. I disconnected the door switch and the short persisted, so I am assuming that the door switch is okay and that the problem is in the drive motor. However, the drive motor is hidden behind the chassis, and I did not have time to dig any deeper than that. And to be honest, I'm not sure I would know what to check even when I got that far. That's where I need some guidance. I've already gone down the wrong road once. Can someone have a look at the wiring diagram and suggest what I should check next? I know that this problem is pretty simple, but I am at a loss as to where to go from here. Thanks in advance for any suggestions and advice! - O.P. File Attachment(s): Old Peculier attached the following image(s):
Groups: Expert
It is normal for that wire to show a dead short to ground with the door closed but if you fully disconnected the door switch and still show a dead short, then you need to trace the wire all the way down to the motor. It may be chafed through at some point and grounding out but this wire is at ground potential anyway. In a dryer with a 3 prong power cord, neutral and ground are tied together at the dryer cord connection block. Your reading of a ground on the black wire with door switch disconnected is suspect so definitely check that out first. At the motor, it connects to the centrifugal switch which is open when the motor is not running. If it turns out that there is nothing wrong with the black wire I would check for a grounded heater element. There is also the possibility that the breaker is just going bad. If you have a clamp on ammeter, you could check the current draw when the dryer is running in a heat cycle.
Eric
