kss18
#1 Posted : 10 years ago
kss18
Can anyone tell me if the Kitchen aid dishwasher KUDPFL01BL5 comes with a check valve in the drain hose? I found two drain hoses, one with and one without.
I am planning to replace the chopper assembly (dirty dishes on the upper shelf); also suspect the drain hose, if it is draining waste back into the dishwasher through a leaky check valve, if there is one. I did find another check valve inside the sump well near the chopper assembly. Don't know if there is a second check valve on the drain hose.
Thanks for any help -- I found two drain hoses for this model, one with and one without a check valve. Grrr.
Extend dishwasher drain hose for Whirlpool dishwasher (Dishwasher Repair)
by skunk_ape 6 years ago
3 connections to LG dishwasher drain hose (Dishwasher Repair)
by powerscott 12 years ago
Bosch Dishwasher Drain Hose Access (Dishwasher Repair)
by gerald_dain 16 years ago
