I have the front right element not heating up and I am wondering if it is able to be replaced. My setup is that I have a cooktop and a Amana oven directly beneath it. (See attached Photo) In order to get the cooktop out will I need to remove the oven also? If so is this going to be a pain? I am assuming that there is some sort of a clamp holding the cooktop to the granite countertop and its being covered by the oven. If that is the case once I remove the oven I can give model number of cooktop to find replacement burner element. If any further information is required please let me know. Thank you for any assistance.:) LavaPit attached the following image(s):
Update.. I saw a few screws in the oven and removed them but after that it looks like the cooktop was just laid in there with some sticky tape so now I have to cooktop out. The model number is J P930K0C1CC. Now to figure out how to get to the element.
Is there anything else it could be except the burner element?
Also it looks like the part is WB30T10044 Thanks
THIS FORUM IS DEAD!!!!!!! |
