AppliancePartsPros.com
Appliance Repair Help
Dishwasher Repair
Dishwasher not Draining, all usual suspects cleared
I've cleared all the hoses and base drain, filter ect.
Then I bought and installed a new pump and solenoid, but it still will not drain.
When I turn it on, the washer sprays water and I can see the pump working. Then when it comes time to drain the solenoid pulls the flap down and the pump still spins yet nothing drains.
I've taken it apart 3 times now to inspect everything is cleared.
I even drained the water by hooking my shop vac to the drain pipe and pressed the solenoid valve down. By all logic it should be working.
Please help me figure this out before I have to waist money on another Washer.
Dishwasher Repair
