Like an idiot i did not turn the breaker off while changing the lower element because oven was not getting past 100. I heard a pop when removing the element, Now the lower oven does not respond to bake broil or clean. I did reset breaker and changed element. Not sure if i blew the board or a relay. If anyone can help, please. Thank you
Did you ever figure out the problem. Did same thing on my oven now nothing works. Trying to fix.
