You have been a member since:: 1/31/2015(UTC) Posts: 4
I just replaced the motor and must have a wire crossed someplace. If I turn the timer to a run position, the gas will start burning, but the motor doesn't turn. Pressing the start button doesn't seem to do anything. Any help would be greatly appreciated. Thanks, -Todd
Groups: Expert
Model number doesn't come up. Did you mean 110.72902100 ? If so, use attached tech sheet. Second diagram is for your gas dryer. Eric
Hello Eric, You are correct. I tyoped the model. It is 110.72902100. Thanks for the wiring diagram. I double checked all of the wires and they all look good. Do you know if there is any way to test the motor? It is brand new and turns freely, but doesn't turn when everything is plugged in and you press the start button. But the gas starts burning so i think the controls think it is turning. Is it possible that the centrifugal switch is stuck on so the motor thinks it is turning when it isn't? Is there any way to test or reset it? Thanks again for your help. -Todd
Groups: Expert
Unplug the motor connector. If burner no longer lights when timer is turned on, then there is something wrong with the motor assuming you didn't mess around with the wiring.
Eric
Thanks Eric, I have returned the motor to the people I bought it from. They are going to send me a replacement. Thanks again, -Todd
