ge hotpoint wont agaite or spin but will drain and no led light at all on motor
Since you are not getting an error code this suggests that replacing the motor, which has the inverter with its error code generator on it, is the solution. That is an expensive part but if you buy from this site and that does not fix the problem you can return it.
