The Electronic Control system seems to be inoperative (Oven, Clock, Timer etc) The Diagram of EC shows a fuse in circuit but I can't locate it. Would like to check that first before going further. Can you help ? Thanks Bob Henson
I cannot find any info on the given model number. Please check it.
If the fuse is in the wiring supplying power to the control board is probably up by the control board in one of the wires. It will look like a little torpedo without the fins. You have to check it with a meter as usually there is no visual indication that it has blown. |
THIS FORUM IS DEAD!!!!!!! |
