RDLearned
#1 Posted : Monday, January 26, 2015 3:20:49 PM(UTC)
RDLearned
I have a Whirlpool Double Oven Model RBD306PDB12 that is approximately 12 years old. The display has stopped working. All the buttons still beep when pushed. If I turn the power off and back on the oven will try to work. It will start to warm up but after about 30 seconds it turns off and beeps. The display never works during all of this.
My question is do you think it is the control board which is NLA or could it be the control panel which is still available? Also is there a way I can test either to see what the problem may be?
Thanks very much.
RDLearned
#2 Posted : Wednesday, January 28, 2015 12:59:17 AM(UTC)
Parts for Whirlpool RBD306PDB12 Oven - AppliancePartsPros.com
Sounds like a control board problem.
All the control panel does is input switch closures to the control board and since you are getting beeps I would say it is OK.
There are companies out there that will repair obsolete control boards/timers.
RDLearned
#3 Posted : Wednesday, January 28, 2015 5:26:47 AM(UTC)
RDLearned
Originally Posted by: denman Go to Quoted Post
Thanks. I had seen that parts list. My board is NLA. I sent it off to be rebuilt yesterday. Will update with results when I get it back.
RDLearned
#4 Posted : Sunday, February 8, 2015 5:36:18 AM(UTC)
RDLearned
Received rebuilt board Friday afternoon. Sent it to fixyourboarddotcom. All is fine now. Thanks for the help.
