lkost
#1 Posted : Tuesday, January 20, 2015 10:25:47 AM(UTC)
lkost
When operating the right front or right rear burner, everything operates correctly.
When operating either the left front or left rear burners independently, they operate but all the others keep sparking. When both left burners are turned on all burners operate correctly.
When all four burners are turned on, they all operate correctly.
I have replaced the top, burners, orifice holders and ignitors.
Don't think in can be the switches. Also doesn't seem to be the spark module.
Could it be that I may have switched the left side spark wires on the left side burners? Another thing I noticed was that the spark wires and connectors were not in the best shape, so I tightened up the spade terminals with my needle nose. The insulation on the ends of the female spade connector had worn off t a little but again I can't see how that could be the problem.
What's going on?:confused:
