redpyll
#1 Posted : Wednesday, January 14, 2015 10:26:00 PM(UTC)
redpyll
Folks,
I have a basic Ikea dishwasher, made by Whirlpool, which was last working 3 weeks ago.
I went to go use it two days ago and there was no response, despite turning the dial from pots and pans, through to dry (no fancy buttons, just a dial). Checked the power, circuit breaker, no issues.
I took it apart and discovered the wiring diagram behind the door panel and have included it here.
I've tested the door switches, timer, fill valve, float, motor, and thermal fuse and they all seem to check out. i.e. show continuity and reasonable resistances. However, it's still not working...
Could someone please post the tech sheet for this model? Or give me an idea of what resistances I should be expecting for each part?
Thanks!
p
redpyll attached the following image(s):
redpyll
#2 Posted : Sunday, January 18, 2015 9:04:42 PM(UTC)
redpyll
Heh, turns out it was a loose connection to the main power! After I put everything back together again, it worked!
p
