Evaporator fan in the freezer compartment goes on and off and on and off continually. We have replaced it in the previous month because we had been hearing noises that the fan was trying to start many times and would eventually start. Replacing the fan did not solve that problem, but now we have a new problem. We have shut it down overnight and it starts fine and runs ok for a while but then the fan in the freezer starts the on and off running again. The freezer is cold,but the fridge is not cold enough. The coils have frost on them inside the freezer after it runs awhile.
What you will need to do is change the adc this is the part number 241508001 wich you can order with Appliance Parts Pro
#centralfloridaappliance.com
Thanks for responding. I will try that and hope that works !
