Hi, I have a GE model #DDE7109SBL, in the timed mode the dryer heats intermittently, most of the time the heat never comes on. In the automatic mode the unit heats and seems to work properly. Not sure of the diagnostic procedure since I've never worked on a dryer before. Would like to get some ideas on which components I should be checking for this problem. Thanks in Advance
Groups: Expert
