The housing where the soap dispenser inserts is cracked. Water is leaking out of the machine. I can't figure out how to disaemble it to replace it. Where can I get a diagram that shows me how to take it apart?:
Take off the top and see if that doesn't give you access. If you still have problems check your model number as I cannot get it to come up on the Sears site to see what the machine looks like.
