debvic13
#1 Posted : Thursday, February 14, 2008 1:30:02 PM(UTC)
debvic13
I can't figure out how to get the old broken dial and knob off my washer in order to replace with the one that arrived today from appliance parts pros. Help!? I have looked at the diagram, it is of no use to me. Does anyone know how to do this?:confused:
abbie
#2 Posted : Thursday, February 14, 2008 6:19:51 PM(UTC)
abbie
Dibvic..Pull the plug so there no power. Pull out the knob as if you were going to start the washer,try to get a small pair of needle nose behind the knob to hold the shaft.Then turn the knob counter clockwise while holding the shaft until knob is off.Then just put a straight screw driver behind the dial so that you can pop it off..good luck
