CharleneBouma
#1 Posted : Tuesday, January 6, 2015 4:44:27 AM(UTC)
CharleneBouma
You hit "Pre-heat" and the temp you want your oven it shuts off you do this about 5-10 times then finally it will click on and heat up....what is going on with this oven? All the burners work just fine. When you hit "Bake" you cannot even try to adjust the temp, and before in the past you could....HELP. I might just need a new range but I dont want to spend the money right now. Can anyone help me with this problem?
#2 Posted : Wednesday, January 7, 2015 1:27:06 AM(UTC)
Parts for Frigidaire FEF368CCSC Range - AppliancePartsPros.com
Sounds like a control board/timer problem.
Unfortunately this part is obsolete.
