The fridge works fine. Doesn't run loud. Then one day you open the fridge and the only thing that works are the lights. I turn the thermostat to see if that will make it work but nothing. No clicking. Let it sit for a bit and it comes back to life. Thermostat will now click. Could it be as simple as the thermostat? I also vacuumed the front coils as it was packed with dust. Should I still look at replacing thermostat?
Tyler
Here are your parts Parts for Whirlpool GR9FHKXPQ00 Refrigerator - AppliancePartsPros.comThe most likely culprit is the thermostat. Could also be that it is getting stuck in a defrost cycle. When it happens again turn the defrost timer cam if it starts up then I would replace the timer. Could be that there is nothing wrong with the unit as you said that it runs fine. So unless you have a problem with the temperatures the unit is probably OK. Every 8 hours or so the unit will go into a defrost cycle, this will last for about half an hour and the fans and compressor will not run. |
THIS FORUM IS DEAD!!!!!!! |
