artpell
#1 Posted : Thursday, December 25, 2014 1:04:08 PM(UTC)
artpell
I have a Maytag MEW5530DDW wall oven. It doesn't not heat in broil or bake. I have checked the coils. They are good. I replaced the control panel. The coils lit. I put it in self-clean. It didn't work. Back to square one. I put a new control panel in. still no heat. Goes click, click. Is it the thermostat? Is it Temp. control sensor? Any suggestions?
#2 Posted : Friday, December 26, 2014 1:43:53 AM(UTC)
Parts for Maytag MEW5530DDW Oven - AppliancePartsPros.com
[COLOR="Blue"]Is it the thermostat? Is it Temp. control sensor?[/COLOR]
Could be either one or something different.
Does the unit stay in pre-heat or does ir show that it is ready.
If it stays in pre-heat then the sensor is OK. re: the unit knows the temperature is too low and is trying to raise it.
[COLOR="Blue"]I replaced the control panel. The coils lit. I put it in self-clean. It didn't work. Back to square one. I put a new control panel in.[/COLOR]
Am I interpreting the above correctly re: you replaced the control panel twice?
Also why did you replace the control panel (keypad) and not the control board (clock) as it is the clock that actually does the controlling?
I would start by checking the power.
The control board etc. run off of half the line but the elements require the full 240 volts.
See my usual blurb below. Your unit may be hard wired in so some of it may not apply.
If the power is OK then unplug the unit of flip the breakers off and check the hi-limit thermostat (item 7 in section 02). Both switches should be 0 ohms.
Try flipping the breaker off/on slowly, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR]
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
File Attachment(s):
MEW5530.pdf (221kb) downloaded 5 time(s).
artpell
#3 Posted : Monday, December 29, 2014 8:47:42 AM(UTC)
artpell
Thanks for responding. It was the control board that I replaced not the panel. I think it goes into preheat, as display lights, and i hear clicks, but no heat. Thing that is weir is that when I put the first board in the coils lit. then when i put oven into self clean, nothing. Now with new board, no coil heat. Is it the thermostat? I understand there could be wiring problems, but given that it worked with board one, it seems unlikely that wiring went out. Ideas?
#4 Posted : Tuesday, December 30, 2014 2:29:32 AM(UTC)
[COLOR="Blue"]Is it the thermostat?[/COLOR]
I cannot say, you have to check iot with a meter.
