mike44
#1 Posted : Thursday, December 25, 2014 6:44:59 AM(UTC)
mike44
I have a kitchen aid kers807sss0 oven and the broiler wont work. Anybody have any ideas as to where to start looking for a solution....
Thanks in advance, Mike
#2 Posted : Thursday, December 25, 2014 7:37:32 AM(UTC)
Parts for KERS807SSS0 - AppliancePartsPros.com
See the attachment for the tech sheet
You seem to be missing the last digit so will have to choose the correct unit from the Matching Model Numbers section.
I am assuming that everything looks normal on the control panel.
Have you tried Full Broil and Center Broil ?
If neither work then odds are that the control board is bad.
You could unplug the unit and check the broil elements with a meter.
The outer should be around 40 ohms.
The center shuold be around 30 ohms.
File Attachment(s):
KERS807.pdf (898kb) downloaded 0 time(s).
mike44
#3 Posted : Thursday, December 25, 2014 10:07:12 AM(UTC)
mike44
I did check the elements and it seems that neither one gave a reading. I did the continuity test.think it may be the element? Would boyh crap out together??
#4 Posted : Friday, December 26, 2014 1:15:25 AM(UTC)
[COLOR="Blue"]I did the continuity test.think it may be the element?[/COLOR]
If they failed the continuity test then they need replacing even if there is another problem in the unit.
You could check the bake element just to be sure you have not made a reading error.
[COLOR="Blue"] Would both crap out together??[/COLOR]
Probably not but you may not have noticed that one element was burned ut and then the other one burned out later.
mike44
#5 Posted : Friday, December 26, 2014 3:05:51 AM(UTC)
mike44
I will try to get one today and update yo with the results. The oven has been taking a long time to heat up recently and things dont seem to be cooked as they should, so maybe one did fail and I didnt realize it then the other went too and now im in the situation Im in now.
Thanks for your help! I will repost results when I get the new one installed...
Merry Xmas
mike44
#6 Posted : Friday, December 26, 2014 12:22:03 PM(UTC)
mike44
Merry Xmas
UPDATE... I installed a new broiler element and all is well!! Thank you for your replies and help..
Mike
