MJJ7000
#1 Posted : Sunday, December 21, 2014 11:46:59 AM(UTC)
MJJ7000
The range top and and over abruptly stopped working yet the lights on the control panel all function properly. Have unplugged the 220V plug to possibly reset -- didn't help.
#2 Posted : Monday, December 22, 2014 1:05:51 AM(UTC)
Here is the tech sheet.
http://manuals.frigidaire.com/p...pringfield/316904444.pdf
You will have to check the power with a meter.
Looks like on this unit the control board controls both sides of the line.
So if you have 220 from L1 to L2 connections at the control board then odds are that the board is bad.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
If OK
Check for 240 at the control board.
