Groups ready for retrieval: Registered
My Whirlpool Cabiro washer does not dispense the bleach. I assume the Electronic Control handles that function. Want to make sure I don't buy the wrong part. Has anyone else had this problem?
Steve
There is a pryout tab on the dispenser cover, use it to remove the cover and check for any obstruction in the line to the dispenser from the fresh fill inlet. You may want to raise the top to check everything also.
I dont' think it is an economical decision to replace parts to fix this problem. If it prevails I would just manually add the bleach, diluted as necessary, during the fill process.
