leeelson
#1 Posted : Sunday, December 21, 2014 10:55:01 AM(UTC)
leeelson
A periodic loud noise comes from the freezer compartment. Its getting worse. Both compartments work fine. I have a parts diagram and it shows a "fan blade" and motor at the back of the freezer. Not sure if this is the evaporator fan. I would like to get a service manual and any suggestions on troubleshooting this problem. Other posts seem to indicate this fridge is made by Whirlpool, and that there are service manuals for other models. Can't find one for this model. Implications are that there is a diagnostic test that can be performed. Any help is appreciated.
leeelson
#2 Posted : Monday, December 22, 2014 8:29:09 AM(UTC)
leeelson
An update:Found a service manual for a different model, but seems similar. Took off lower panel in freezer. Evaporator fan seems to run quitely. Testing pins 1 & 4 of the motor (red & white wires) gives 2 ohms on most scales. On lowest scale reading briefly is at about 155 ohms, then goes to open. Blue wire to motor is not used. W/ fridge on, get 12VDC between red & white and with fan off, get about 1VDC between yellow and white. With fan on, yellow/white goes to about 7VDC. Evap fan part: Panasonic UDQT22WP1.
Sub-Zero new model makes loud noise (Refrigerator & Freezer Repair)
by Guest 5/3/2024 7:49:55 PM(UTC)
Loud noise at start of spin cycle that stops once at high RPM (Washer Repair)
by tollisal 1/28/2023 8:48:50 AM(UTC)
LG LG WM2016CW Side load washing machine loud noise (clip included) (Washer Repair)
by Guest 9/29/2022 5:53:08 PM(UTC)
GE washer: loud noise when spinning (Dishwasher Repair)
by Guest 8/7/2022 12:54:21 PM(UTC)
GE Refrigerator #GSHS5KGXBCSS No water and loud noise after filter replacement (Refrigerator & Freezer Repair)
by Guest 8/26/2021 6:48:33 PM(UTC)
MAV7600AWW makes loud noise during spin cylce (Washer Repair)
by Guest 6/14/2021 6:09:42 PM(UTC)
Whirlpool Cabrio Platinum - Loud Noise at Start (Washer Repair)
by jlucenius 1/19/2021 2:05:51 PM(UTC)
Loud noise during anti static cycle on my Frigidaire dryer (Dryer Repair)
by GR8TSCT99 5/1/2019 4:40:02 AM(UTC)
loud noise during the spin cycle (Washer Repair)
by cznlzq 4/24/2019 6:30:35 AM(UTC)
LG Gas Dryer - loud noise, now won’t come on (Dryer Repair)
by Benay 3/4/2019 7:20:40 AM(UTC)
Water Dispenser Makes loud noise now (Refrigerator & Freezer Repair)
by zamboknee 1/5/2018 12:45:09 PM(UTC)
Maytag Centennial single loud noise when spin ends (Washer Repair)
by BigRenwick 2/27/2017 5:41:58 PM(UTC)
Horrific Loud Noise - Can't Find Solution (Washer Repair)
by PetraG310 11/14/2016 12:03:02 PM(UTC)
GE Washer Loud Noise (Washer Repair)
by rock324 1/29/2016 12:05:58 PM(UTC)
Kenmore washer 70 series loud noise issues (Washer Repair)
by wagnerplp 1/26/2016 9:20:19 AM(UTC)
