AppliancePartsPros.com
Appliance Repair Help
Washer Repair
cannot separate upper agitator from lower as shown in video
Whirlpool model LSN1000KQ0 – I can’t separate upper agitator from lower agitator as shown in repair video. Short cam agitator repair kit (part AP3094543, Mfg # 285809) for Whirlpool LSN1000KQ0.
Your video shows the upper agitator easily lifts off lower agitator and cam assembly falls out of upper agitator when it is tipped upside-down. I can’t separate the upper and lower agitators and the cam will not come out of the upper agitator. I have removed the entire agitator assembly (both upper and lower) and exerted quite a bit of force to try to separate, also inverted entire assembly and cannot get old cam out. Advice???
Ok, I solved my own problem and thought somebody might find it useful to know what happened. So, about 25 seconds after I posted my question and didn’t receive a reply I became impatient and started trying to figure out what was going on (this is an especially impressive display of patience on my part, just ask my spouse). First, after reviewing more posted questions related to this problem (links displayed to me after I posted), I saw a couple recommendations to “soak the agitator in hot water”, I tried that and it didn’t work (and as it turns out no amount of soaking would have helped). Next I examined the cam, dogs and retainer ring closely. I noted the new cam has 4 slits at the top which seemed to be made to receive tabs from the agitator … so looking at the old cam stuck in the agitator, sure enough one slit had a white tab from the agitator and the other 3 slits had melted globs of agitator plastic. Looks like the factory agitator was made to clip the cam in place, but that wasn’t enough for the factory they decided to apply heat and melt the tabs into the cam. Before destroying the tab system to get the old cam out, I was concerned about what would hold the cam and prevent it from sliding around when the agitator was agitating, I examined the new cam and saw 4 slots that would fit over the agitator – no sliding. I also determined the bolt would hold the cam down so the tabs weren’t needed for that. Next step, get the old cam out without destroying the agitator. I used a sharp utility knife (trust me, a dull utility knife won’t work) to cut away enough of the melted plastic to eventually pull the cam out (gripping with a needle nose plier). I’m sure there is an easier way, but the utility knife worked for me. I cut the plastic that used to be the tabs off the agitator and reassembled the entire mechanism without further incident. Problem solved … in about 3 hours versus the 3 minutes depicted in the repair video … but still – problem solved. Good luck to all, be safe.
Thanks for posting this I had the same situation and because of your information I used a drimmel tool(rotary tool) with a high speed cutter attachment to shave off the white tabs gripping the cog and once done it came right off super easy just like in the video. Waiting for my parts to arrive and repair in the mean time i an replacing the agitator and it will function just as before lower working upper not. Expecting the parts in a few days and then back in business. Thanks again
Rank: Guest
Groups: Joined: 8/10/2018(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: 99556 Was thanked: 4 time(s) in 4 post(s)
@CCarlson500 you have as much patience as my husband! My washer was purchased in 1998 (25 years ago) and am just having the agitator issue. Our tabs were melted, as described - clearly they were willing to spend the extra minute in the manufacturing process back then. Once whittled away it came apart - like a firecracker with parts flying, but it worked!
Washer Repair
