AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Washer won't start water flow when hot water is selected.
The washer will not start water flow when hot water is selected. At times if I jiggle the timer/start knob just right the flow will begin. Works fine in cold and warm settings. It seems that the issue lies within the start knb/timer assembly. Can anyone tell me what the issue is and what part is the problem? Thanks!
Please check your model number as no model matching it is coming up.
Then you can go to the parts page on this site and using that number you will be taken to an exploded view of your machine and you can see the timer or other parts that you will need.
Good luck.
Washer Repair
