I have a Whirpool Double Oven that went completely dead after the self cleaning cycle. I have determined that the thermal fuse in the wire harness near the control panel has blown and needs replaced. I am looking for a part number or applicable substitute part to replace this thermal fuse. Any help is greatly appreciated.
The thermal fuse is a very common item, find the temperature rating, usually in degrees C. Believe it or not Radio Shack actually sells some of the fuses, they are not expensive.
Hope this helps - Jim
