Help. Went into fridge this am. Fridge not cold, checked freezer, food half defrosted. Has power, light on. Evap. fan not running, cond. fan not running, comp. not running. Turned temp control off then all the way to 9. Not running. Unplugged unit, plugged back in, not running. Emptied unit. Pulled out, comp. cold to touch. Cond. fan spins by hand. Smacked compressor with hand, not running. Tilted unit back, checked cond. slightly dirty, cleaned. Put unit back on all fours. Not running. Scratching head, what to do next, comp. turns on by it's self. Check evap fan, running, Ck cond. fan running, unit getting cold.
Whats up?? Stuck defrost controller?? Bad temp controller?? or ???
THANK YOU FOR ANY HELP!!!!
